Re.Identify Model
dan duvall
03-14-2006 21:52:30
Egg lady gave me an old tractor. I need to know what model it is, front tires are wide apart, back tires are13.6x28,and 6 bolts. back axle by brake spring left side,front with raised letters is C-LC-KL, Right axle by brake spring says CL-7-KC. Brake housing down low says 103705, Transmission right side says 207365 left side 206875,steering wheel 135050,gas tank has small inditation where steering column goes thru, top hood has exhaust on right, breather on left. help.
Texas Denny
03-15-2006 20:31:02
 Re: Re.Identify Model in reply to dan duvall, 03-14-2006 21:52:30
I read your note again. I don't know of an Allis with the exhaust on the right or with the steering through the top. If you don't want to post a picture in help identify, you could just start browsing through the tractor photos. With what you told us, it is more likely a John Deere than an Allis. Need picture.Re
Duncan
03-15-2006 19:32:01
Just from the steering description its something other than an Allis Chalmers.
Texas Denny
03-15-2006 05:49:59
Under Galeries on the left side of this page is a heading "Help Identify". Place a picture in there and let us know when you have done it. A picture is worth 10,000 numbers.
