allis B block
Spack
03-14-2006 18:13:30
I am rebuilding an Allis B ,have checked 3 blocks ,all are cracked between sleeve bore's. Talked to an old Allis mechanic about repair. He said to just put her together and don't worry about it..... .... I still worry ,any suggestions?
old
03-14-2006 20:55:49
 Re: allis B block in reply to Spack, 03-14-2006 18:13:30
Yep pretty normal. If you want another block let me know I have one in a parts C, same block it includes pistons rods and crank. I would love to see some one get it and use it instead of it rusting away. E-mail is open
ricedaddy
03-14-2006 19:09:48
AC had BAD problems with cracks, at the time they came out with a kit to repair, but thats been along time ago, like the others has said if there not to wide put her together and hope for the best! And don't forget Barsleak
bw in mo
03-14-2006 18:37:05
Yes put er togather don't worry..
steve(ill)
03-14-2006 18:22:15
if the crack is something like .010 wide, then you are normal, all that way. if you can stick your fingernail in the crack, that is getting a little wide and needs additional repair. --- the head gasket will seal small cracks.
Spack
03-14-2006 18:26:28
 Re: allis B block in reply to steve(ill), 03-14-2006 18:22:15
Thnaks Steve . They are very small,not opened up at all,and just in the top of the block .
Dick L
03-15-2006 04:39:18
 Re: allis B block in reply to Spack, 03-14-2006 18:26:28
Those are heat cracks. You will find them in all wet sleeved engines that was allowed to over heat past the red line. Not confined to Allis Chalmers.
