WD HELP
ryanfisher
03-13-2006 14:34:04
HI! I am looking at WD to buy for $250.00. engine stuck, and I am looking to run feed grinder off belt pulley, but there isn't one there, anyone know of where i can get one and how much $$. any help also with freeing the engine.thank you all so much for your help. also what is belt pulley horsepower on these. thanks again
Bud H
03-14-2006 05:07:48
 Re: WD HELP in reply to ryanfisher, 03-13-2006 14:34:04
I have a belt pulley assembly off a WD that you can have free, if you can either pick up or afford shipping. I am located in central New York about 50 miles east of Syracuse. Send me an email.
old
03-13-2006 16:59:41
As far as the stuck engine I use tranny fluid and if that doesn't do it I then top that off with turpentine. So far it has always worked for me but right now I have to engines soaking and they haven't popped loose yet, but they have only been soaking for a couple days.
Texas Denny
03-13-2006 14:42:38
Belt pulleys are available on Ebay almost all of the time. You might check a local junk yard though. Shipping of this item is high cost because of weight. Someone may see this post and have one near you. I do and am in central Texas.
There are lots of ideas on getting an engine unstuck. All the way from ATF to brake fluid and carb cleaner. Most everything will help. I like the misture of brake fluid and mineral spirits.
Belt horsepower is 35.8 if it has stock cylinders.
