Value WD45, D14's, D15, WD parts
Robert Marsh
03-12-2006 10:07:12
Hi, I am not the best mechanic in the world and need to have one running reliable snap coupler allis. I just came across a narrow front D15 with 5000 hours and nice paint for $2,300 and may be able to trade in something(s). I am looking for advice on values and what would be good options for trading / selling what I have. I do not want a loader on the Allis, and narrow front is fine.
I have a WD45 wide front with trip bucket loader and front bale spike, power steering. 98% rear rubber, runs well but rusty EXCEPT the hydraulics will not longer pick up 5x6 bales (picks up a little way very fast then stops, picks up 4x5 bales fine) AND the tranny is now stuck. It stuck in gear a few years ago, I started to take the top off, and it started working again. This time: Stuck in 1st, I took the top off the trans and it worked fine, stuck in reverse when I put it back together. Taking only the gear shift out I now have it locked up. I have the 3 slides lined up (but the one on the left has some sort of indent thing) but is locked in two gears I assume now (motor lugs down with pull on hand clutch). I have a NEW shift lever, no difference.
I have a WD that I used for 18 years, 3 years ago plowing snow (it ALWASY started so was my winter tractor) loud clank in the motor, I parked it. Everyting is well worn, 75% + rear rubber. Narrow front.
D14 narrow front with nice trip bucket loader but bad hydraulics. It had water poured in the gas but ran well until then. 30% rear rubber with repaired rims.
D14, faded original paint, runs good. Wide front with trip bucket loader and rebuilt hydraulics. Almost new rear tires, one bad front wheel (cracks and use washers to hold on but it works). Stout 3 point adaptor.
Any help is appreciated.
Thanks,
Robert
