D-12?
DH in SC
03-11-2006 17:34:04
New owner of a D-12? Did the web search thingy and have found serial# breakdowns, and even more confused. Throw out bearing locked up and ate arms up on pressure plate. New kit had a pilot bearing that tractor didn't have. Forgive me, but not a tractor expert. We could have converstaions on British cars tho. Number on left engine flange is 10-1373S, number on adjacent xmission flange is not as readable, but looks likt D 7(?) 0(?) 1140. Looks to be original paint, hood has D-12 decal on it. Beautiful running tractor, prime candidate for a little restoring, But wish I new for sure what I have. Any help would be deeply appreciated.
ricedaddy
03-12-2006 15:06:26
 Re: D-12? in reply to DH in SC, 03-11-2006 17:34:04
Allis Chalmers
D12
Manufactured: 1959 - 1968 Factory: West Allis, WI Cost: (US Dollars) $3,522 (1968) Power: Engine (HP): 31 Drawbar (HP): 23 PTO (HP): 28.5 Engine: Manufacturer: Allis-Chalmers Fuel: gasoline Type: vertical L-head Cylinders: 4 Bore/Stroke (inches): 3.375x3.875 Displacement (ci): 138.7 Compression: 7.75:1 Rated RPMs: 1650 Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Type: sliding gear Forward: 4 Reverse: 1 Capacity: Fuel (Gal): 12.5 Cooling (Qt): 8 3-Point: Category: snap couple Lift (lbs): Power Take-off (PTO): Type: Rear speed (RPM): 540 Tires: Ag front: 5.00-15 Ag rear: 11-24 Dimensions: Weight (pounds): 2,800 Wheelbase (inches): 78.75 Length (inches): Width (inches): Height (inches): 77 Ground clearance (inches): Electrical: Battery volts: 6 Ground: Battery cold-cranking amps: Alternator amps: Nebraska Test: Test Number: 723 Test Date: October 1959 PTO HP: 28.6 Drawbar HP: 23.6 Max pull (pounds): 2,057 Nebraska Test: Test Number: 813 Test Date: 1962 PTO HP: 33.3 Drawbar HP: 29.4 Max pull (pounds): Serial Numbers: Location: Torque housing 1959 1001 1960 1950 1961 2801 1962 3638 1963 5501 1964 6012 1965 9192 1966 9508 1967 9830 Links: To suggest a link, please see these guidelines.
NBAllen
03-14-2006 13:31:45
 Re: D-12? in reply to ricedaddy, 03-12-2006 15:06:26
good info here...looks like the info came from tractordata dot com - I figure it'd be polite to throw in a credit for the information source.
*smile*
Disclaimer - I have no affiliation with tractordata dot com, but go there often and recognize the data format. N.
JMS/MN
03-12-2006 09:34:57
The tractor serial number is on the left front flange of the torque tube, starts with D and the model, then up to five digits. They are stamped, often hard to read- try some paint remover to make them more visible, or careful wire brushing.
CHALMERSBOB
03-11-2006 19:02:21
DON'T KNOW ABOUT THE 10XXX ON THE ENGINE FLANGE, BUT THE D12 AND THE D10 HAD THE SAME ENGINE. SO THIS IS POSIBLE. D12 WAS WIDER THEN THE D10. D10 WAS STANDARD WIDE FRONT AND D12 CAME WITH NARROW FRONT, WIDE FRONT, AND SINGLE FRONT WHEEL. D10 REAR WAS ABOUT 48 TO 50 INCHES WIDE AS D12 WAS 72 OR SO INCHES WIDE.
SEEM TO ME THAT THE SERIAL # WAS ON THE BELL HOUSING FLANGE, AND THE ENGINE SERIAL # WAS ON THE BLOCK NEAR THE AIR CLEANER. EARLY MODELS WERE 138 AND LATER WERE 149 CU. IN. ENGINES.
HOPE THIS HELPS.
BOB
