Kent of SW MO (wood splitter)
LWD
03-10-2006 23:07:02
I got a 2-stage pump this week, problem is finding a pump mounting bracket to fit my old briggs@straton 8hp. motor, the bolts are 3.5" apart and my shaft is 3.5" long, I guess I`ll have to make one. what oil do you use? thanks much
LWD
03-12-2006 13:38:45
 Re: Kent of SW MO (wood splitter) in reply to LWD, 03-10-2006 23:07:02
Kent thanks for your help, I thought it was 1/2 pipe because it had the same thread pitch and so close to size, with out your help I surely would have mest it up.
LWD
03-12-2006 11:53:49
I found one more problem, I got a barnes pump and the pressure port is to tight for a standard half inch hydraulic male end, 1/2 npt. the male end is about 25 thousands to big for the port hole, what now?
Kent of SW MO
03-12-2006 12:57:42
 Re: Kent of SW MO (wood splitter) in reply to LWD, 03-12-2006 11:53:49
Are you sure it is pipe thread? It may be o-ring also known as JIC.
Kent
Kent of SW MO
03-11-2006 08:12:25
Surrplus Center in Lincoln,NE may have the mount for the pump. You oil question, I take you mean Hyd. Oil? You could use type A/mercure(sp?) ATF like my C-II Gleaner uses or you could use the Universal Hyd. Oil like WallyWorld or about any farm supply store has.
Kent
