Allis G...How to correct slop in gear shift lever.
BWA
03-10-2006 19:00:14
Am repairing my Allis G transmission. Have replaced all the bearings and oil seals, But how is the best way to correct the slop (excess play) in the gear shift lever? Any help would be appreciated.
kevin (LA-CA)
03-11-2006 05:47:36
 Re: Allis G...How to correct slop in gear shift le in reply to BWA, 03-10-2006 19:00:14
On Dad's G, I removed snap ring & pulled the lever. Then welded up the swivel ball and worn areas near the slot. Ground it back to size and finished shaping the ball and slot with a good file. Replaced the two guide pins from AGCO. May have added a little weld to the tip.
Removed about 80% of the slop. Can really find 1st and L now. Takes about 1-2 hours.
