D-17 series 4 gas engine serial 79321 engine bolt
Carl LaBrake
03-10-2006 04:04:58
I have bought a shop manual AC-201 but it does not give these values except head. Please help me with all these engine bolt torque values. Thank you...
TexasAllis
03-13-2006 11:14:51
 Re: D-17 series 4 gas engine serial 79321 engine b in reply to Carl LaBrake, 03-10-2006 04:04:58
You will probably need to consult a shop manual. The head, rods and mains are critical so the values are in the service manuals. Most dealers that work on Allis will have one. You might find the values there. I have had all those parts off of my D-17 and just tighten by hand. I have had no problems.
Carl LaBrake
03-13-2006 12:22:23
 Re: D-17 series 4 gas engine serial 79321 engine b in reply to TexasAllis, 03-13-2006 11:14:51
Yes, I want to thank you for that information. I finally found an old dealer who has helped me out. As a good mechanic I understand how critical every nut and bolt torque on any engine is. The information is out there, what bothers me is buying a [shop manual] that doesnot have all the critical information. Again I want to thank the forum for this opportunity to gain knowledge.
03-10-2006 17:17:32
What bolts are you referring to ?
In I&T's AC-201 Manual
pp 77,(page 26)
Rod bolts are to be torqued to 45-55 ft lb
pp 80,(page 27)
Mains are to be torqued of 130-140 ft lbs
There are a lot of sites that have torque charts for common fasteners not covered in shop manuals.
Here's one....
Carl LaBrake
03-10-2006 18:26:50
 Re: D-17 series 4 gas engine serial 79321 engine b in reply to [email protected], 03-10-2006 17:17:32
So sorry, you are correct on those torque values. What I need are the intake/exhaust manifold, valve cover, rocker arms, carburetor bolt torque values. Thank you.
