Clutch
Cory
08-11-1999 18:49:58
I have a 1949 WD that needs a new clutch. Would a clutch from a WD45 be a better unit? What are my options? Thanks
Bud DeLong
08-16-1999 19:07:54
 Re: Clutch in reply to Cory, 08-11-1999 18:49:58
Which clutch?? The engine clutch[seldom used],or
the mutiple disc wet second clutch that with easy
adjustment proably has out lasted most owners??
Bud DeLong.
Brian Goodfellow
08-12-1999 05:30:38
Cory, According to the I & T Service Manual,"Models WD & WD-45 tractors are equipped with either a 10" model 10RM Rockford clutch or a 10" model A-10 Auburn clutch." The clutch cover (pressure plate) ass'y. for the Rockford is: R4259; the Auburn: 100057-1. Flywheels for each type of clutch are unique and ARE NOT interchangeable. I'm sure some of the "Pullers" out there can tell you which type clutch is the best and probably they have other options for "beefing up" the relatively small 10" clutch. If they do, I'd be glad to hear about that too!Good luck, Brian G.
cory
08-14-1999 16:20:50
 Re: Re: Clutch in reply to Brian Goodfellow, 08-12-1999 05:30:38
Thanks Brian that should take care of the problem,
when i removed the clutch it was coated with lube.
