WC gear shift assembly
Bill Norsworthy
03-06-2006 17:42:28
I have a 47 WC sn 162922 and I need a gear shift assembly or some instructions on doing something with the one I have in very bad shape.
JMS/MN
03-07-2006 11:46:56
 Re: WC gear shift assembly in reply to Bill Norsworthy, 03-06-2006 17:42:28
Problems usually come from two wear points- worn forks, or the bottom end of the shifter shaft. Both can be built up with weld, and ground down to original size. Slot on the ball may also be worn- same treatment, weld and then mill down to size.
