FORKLIFT WONT RUN
THERIGWELDER
03-06-2006 16:54:48
I HAVE AN AC FORKLIFT WITH A 262D MODEL #FSD70-24-PS.IT WAS RUNNING PERFECT THEN JUST QUIT.I HEAR THE PUMP SOLENOID KICK ON WHEN I TURN THE KEY.IVE DRAINED AND REPLACED ALL THE DIESEL. REPLACED THE FILTER.TAKEN EVERY INJECTOR OUT DISASSEMBLED AND CLEANED THEM.CONFIRMED CYLINDER COMPRESSION.I CONFIRMED FUEL WAS SQUIRTING OUT OF EACH INJECTOR TUBE. BLED INJECTORS.ENGINE WILL NOT LOCK UP AND START WITH ETHER,AS MATTER OF FACT ETHER DOSENT HAVE ANY EFFECT.I GET LIGHT,WHITE TO BLUE SMOKE WHILE CRANKING.WHERE ELSE CAN I LOOK?MAYBE TIMING?I ALSO INSTALLED A NEW AIR FILTER AND BATTERY
therigwelder
03-07-2006 05:05:42
 Re: FORKLIFT WONT RUN in reply to THERIGWELDER, 03-06-2006 16:54:48
i will check the timing this morning.if the timing marks line up and it still wont fire i guess i will have to look into the gear idea
therigwelder
03-06-2006 19:50:37
its a roosa DBGFC637-21AL.i am not sure i understand what you mean by a pin on the bellcrank to lock it in TDC.i thought i could just pull the #1 ij. and stick the ol thumb in there for compression stroke?
BCnT
03-06-2006 20:53:44
 Re: FORKLIFT WONT RUN in reply to therigwelder, 03-06-2006 19:50:37
to be honest i dont know where pin is either...book says its got one...i use my thumb too...or a pencil for fine tuning TDC...my pump was a DB too but had manual kill lever...i'm just wondering if solenoid mite not be kicking out far enuff but if it wont pop on ether i'm afraid you got a stripped gear somewhere...i owned a 262 buda diesel...never again...good luck.
BCnT
03-06-2006 19:13:46
it sounds like it may have jumped time but it also sounds like you have a later engine/pump than my manual covers...locate timing marks...it may have a pin/stud on bellhousing that reverses and locks engine at TDC...then look thru window on pump..timing is 23* on a D Roosa.
