WD, D17, E Gleaner
Joshin Around
03-06-2006 16:08:46
I currently Pull a WD Allis Chalmers with an E Gleaner Engine. I changed The rear Wheels from 28" to 13.6 x 38", Striped everything possible off of it, and it pulls well in the 3700 and 4200. It is a First gear tractor but im not satisfied with my ground speed, My association allows up to 5 1/2 MPH. I have tryed to pull it in second gear, but that stalls the engine. I was wondering if the D17 engine would provide more power than the E Gleaner. Im open to all suggestions. Thanks for the INFO.
earl haman
03-12-2006 07:53:06
 Re: WD, D17, E Gleaner in reply to Joshin Around, 03-06-2006 16:08:46
i pull a wc with gleaner engine.pull third gear in 3000 and3500 and second gear in 4500. have 13/6x28 tires on 12 in. rims.usually in top 3.log on to www.wildwheelsweekend.com .click on to antique results . also click on to 2005 participants with logan to see a pic. of my wc. earl
mlpankey
03-07-2006 20:21:56
barney taylors cam is better for pulling than a 170 lobe seperation is tighter he also has a clutch thats better it wil hold well over 100hp. as for the wieghts for governor yes they need saved down alittle .the spring out of a d 17 is out dated most springs now will turn in excess of 2600 rpm the governor has to be a tractor govenor combine govs just dont work .as for barney hes won the super pulls several times and knows more than i .
Bob Allisin Wi
03-06-2006 17:52:29
I don't agree compleatly with that. I have a E motor and have been watching and reading what people are doing. If you seach the pulling discusion page on here you will learn alot. My opinion is to rebuild the govinor weights with 170 or D-17 weights. And use a E motor's Spring. There's something about the E's Weights that they don't lug down right on a puller. as far as more power out of a E Now it is going to cost you BIG, Aftermarket and custom. Good luck
Fruitfarmer
03-06-2006 17:00:49
The E Gleaner and the D17 are pretty much the same engine. Adding an Allis 170 governor spring to your engine will gain some rpms, somewhere near 2500 rpms. The 170 cam will help with breathing also. Best of all, have everything balanced, even though there are no counterweights on the crank. Top it off with a 170 aftermarket manifold, the one with the threaded pipe. Giveaway your Marvel-Schebler TSX 773 if that is what you are using and invest in a modern Zenith replacement. All a matter of money.
