timing of a 180 diesel
Eldo case
03-05-2006 16:32:49
I have timed several diesel engine but have never came up with nothing like this!! It don't have both timing marks in the window of the injection pump just the one that is fixed. We used a magnifing glass it is not their!!! How would one go about timing it? Is their another way? This fat boy is stumped!!!!! ! Please help!!!
Eldo case
03-06-2006 10:10:59
 Re: timing of a 180 diesel in reply to Eldo case, 03-05-2006 16:32:49
I have found out that when some pump rebuilders put in a new governer shaft they forget to put timing mark on it. So you have to air time it!!!! That is what I am about to do now. Then I will scribe a mark on the governer in the pump then the next poor sob will have two marks in the pump to time it by!!!!!
Gene-WI
03-06-2006 06:31:18
Did you have the pump off or what's the deal? If you put the timing mark of the engine crankshaft pulley on 26 BTDC, the mark on the injection pump should be visiable. The mark on the moving part of the pump should be just as easy to see as the stationary one. Is the pump turning? maybe the shaft is sheared off.
