WD 45
Mark Manlove
03-05-2006 15:10:47
I need to know what type of hydrolic fluid or oil goes in the PTO to run the hydrolics in we believe a 52 or 53 WD 45 Serial #195351?
ricedaddy
03-06-2006 19:24:10
 Re: WD 45 in reply to Mark Manlove, 03-05-2006 15:10:47
Mark, did you remember to put the key shaped gaskets between the main cap and the block! I just ran into that myself!
Ron
acnky
03-05-2006 15:27:50
Hy-trans or equivalent,universal gear oil hydraulic fluid. By the way, # checks as 1955.
Mark Manlove
03-05-2006 16:25:17
 Re: WD 45 in reply to acnky, 03-05-2006 15:27:50
Thanks for the info. we have a 45 WC it leaks around the new rear main seal, do you have any sugestions on how to stop it?
Texas Denny
03-05-2006 19:50:38
 Re: WD 45 in reply to Mark Manlove, 03-05-2006 16:25:17
Mark, I have never changed one of these seals without removing the engine. However, you can replace the bottom half of the seal by taking off the pan and the bearing cap. When you put in the lower half of the seal, it will, of course, improve sealing on the bottom half of the seal surface. Since it puts pressure on the top half of the seal, it may make it seal better as well. If the seal has become hard as a result of age or whatever, the new lower half may have no affect on the upper half. But again, the leakiest part is probably the bottom.
Your risk to find out if it helps is the cost of the pan gasket, the seal gasket, an oil change and your time. Might be worth it.
Mark Manlove
03-06-2006 14:52:31
 Re: WD 45 in reply to Texas Denny, 03-05-2006 19:50:38
Thanks for the info. We put a new seal in and it leaks bad when the engine is cold and slows down when it warm up. Mabey we just need to change the seal again. Thanks, Mark
Mark Manlove
03-06-2006 14:52:29
