Model B
marvin
03-04-2006 15:39:31
I bought what I think is a model B today. I have read that the serial no is on top of trans to rear of shift lever. I can not find it. Is it stamped or is it on a tag? If missing,is there another way to find out age of tractor? Thank you for any info.
steve(ill)
03-04-2006 18:30:32
 Re: Model B in reply to marvin, 03-04-2006 15:39:31
the Ba nd C share the same hood, motor, radiator, transmisison , etc. The main difference is the B is about 56 inches wide outside tires in the back, and the C is about a foot wider at 70 inches. these are somewhat adjustable. THe B steering gear box below the gas tank has the arm pointed down, and connects to the left front wheel king pin with the rod. The C has the gear box below the gas tank with an arm pointed up. the rod goes to a second drive box below the radiator area. the pedestol box steers the front end of a C.
RandyN
03-04-2006 16:07:39
Hi Marvin,
Yes, it's on that "flat spot" right by the shift lever. It is stamped in and should start with B, if it's a Model B. Often, gunk and paint can fill in the stamping and make it difficult to find and read.
RandyN
