will it work?
LWD
03-03-2006 17:25:54
I`m thinking of putting a 11gpm. pump on the pto of a `C` to run a wood splitter. can I get by with a 4" cyl or do I need a 5" cyl?
Ted in NE OH
03-04-2006 17:13:41
 Re: will it work? in reply to LWD, 03-03-2006 17:25:54
Most log splitters run on a one cyclendar engine and are fairly economical. I can't beleive that running FOUR cyclendars would be very cost effective.
Kent of SW MO
03-04-2006 08:27:08
You might look at the 2-stage pumps that are built for log spliters. They put out high volume/low pressure until the log put a load on the cylinder which causes the pump to shift to high pressure/low volume. This pump has four times the volumn in low pressure as it does in high pressure.
Kent
Rod (NH)
03-03-2006 18:03:11
It depends on the system pressure and how long a cycle time you are willing to accept. 11 gpm is not that much for a 4 or 5 inch dia cylinder. I use a 20 gpm pump running at about 1200 psig on an Oliver and a 4" dia cylinder. I wouldn't want anything slower - but that's only me. You can figure the cycle time to extend easily enough. For a 5" cyl and 11 gpm, it'll extend at the rate of about 2 inches per second. For a 24 inch stroke, it'll take about 11 sec to extend, a little less to return, depending on the rod diameter. You'll have to decide if that's fast enough for you.
third party image Rod
