E GLEANER COMBINE MOTOR
N1
03-01-2006 14:22:44
WILL A E GLEANER MOTOR FIT IN A WC ALLIS. AND WHAT HP.
wcpuller
03-04-2006 18:31:52
 Re: E GLEANER COMBINE MOTOR in reply to N1, 03-01-2006 14:22:44
i have a gleaner e motor in my wc. stock hp to the ground is 55-60 horses depends on the flywheel you put on it. i have to change the front end on the motor to work in a wc or wd or wd-45. the timeing gear cover, governor and water pump. a gleaner e motor is only a higher rpm d-17 engine thats all. but they will pull. and i also getting a gleaner a2 6 cylinder for a wd-45 also
yorkie
03-01-2006 17:27:33
sure will i have seen alot of them in pulling tractors in ohio around 40 _45 stock hp
