Tire size
Michael D.
03-01-2006 09:10:07
I am looking at buying a set of wheels for a project tractor my son and I are finnishing up. My problem the rims are said to be 5.25X17. I am unable to locate a tire size to fit them. They are for a WC unstyled. My manual says the tire size is 5.25X17. Is there a new size conversion for this tire? Any help would appreciated.
Mike
Spud Ohio
03-21-2006 20:27:30
 Re: Tire size in reply to Michael D., 03-01-2006 09:10:07
Prior to 1936 sn.23529, front wheels are nonreversible spoke type. I have the same problem with my WC. At one time someone made a 17 inch tractor tire. Both of my tires are still on the rims but are shot. They are both three rib tractor tires. I have thought of converting to the disc type wheel. I can see no reason why it will not work. GOOD LUCK.
Bob in Iowa
03-02-2006 19:35:29
I don't think anyone ever made a 17" front tractor tire. If you look at old ads and liturature you'll find the WC shown with car tires on the front and as stated they are available.
George Andreasen
03-02-2006 17:55:51
I can't contribute anything about Allis tire sizes, BUT there definately were 17" tires used on automobiles just before and after WWII. You might try an internet search for "antique automobile tires". It should turn up several specialty outlets. Good luck!
BCnT
03-01-2006 15:53:03
you mite try Coker Tire...i cant find link offhand but do a search...its there...if they dont have tires they may know somebody that does.
Texas Denny
03-01-2006 13:15:29
The outside diameter of a 5x16 rim (which uses the 5.50x16 tire) is about 17". You want to measure the diameter where the tire bead seats. That dimension is 16".
Never heard of a 17" tire on a Allis.
Aaron SEIA
03-01-2006 15:34:36
 Re: Tire size in reply to Texas Denny, 03-01-2006 13:15:29
Just dug out my original 36 WC manual. The factory round spoke front rims were 5.25x17". The pressed steel ones were 5.5x16, so I'd be checking the rims style and measurements as well as reading what came off of it. I don't doubt that what you have is a 17" rim, just make sure before you try to put a 17 on a 16. And, I second the Miller tire web site.
Aaron SEIA
bjb in NE
03-01-2006 10:53:54
Are you sure you have the right size. I have a reprint manual for a styled WC and it says they are supposed to be 5.50x16 tires. If your just measuring the rim dimensions you may have the wrong size. Try the attached link for more information.
JMS/MN
03-01-2006 18:38:01
 Re: Tire size in reply to bjb in NE, 03-01-2006 10:53:54
I think Aaron is right about the 17 inch tire. Question was about an unstyled WC, not styled WC. Styled did have the 16 inch, but 17 inch on the earlier ones does sound familiar.
Aaron SEIA
03-01-2006 15:38:30
Cancel the Miller tire idea, they don't show a 17" front. Think your gonna have a hard time finding a replacement for those.
Aaron SEIA
