casting codes
Joe St. Clair
02-27-2006 14:31:57
Well, I registered my C and have one question. Where would one find the casting codes? I am guessing it would reveal the date the tractor was beginning to exist. Any clue? Thanks for the help.
Joe
Joe St. Clair
02-28-2006 14:16:13
 Re: casting codes in reply to Joe St. Clair, 02-27-2006 14:31:57
Thanks for the information. I have the tractor number with C 26864. Then, just below the gear tree is another number that appears to be stamped into the transmission. It is something like 45261F. Any ideas?
Joe
Texas Denny
02-27-2006 14:57:27
The serial number is on the shift housing below the shift pattern. Once you have that number, look up the age at the left under serial numbers.
Joe St. Clair
02-27-2006 15:29:29
 Re: casting codes in reply to Texas Denny, 02-27-2006 14:57:27
Thanks! I found a number under the shifing pattern. It is 45651F. Does this sound right? I will put it in the serial number finder and find out what I got!
Thanks again. Joe
JMS/MN
02-28-2006 06:53:19
 Re: casting codes in reply to Joe St. Clair, 02-27-2006 15:29:29
Serial numbers are stamped- not cast. Your serial number should start with a 'C', then up to 5 digits.
