Ok what is it, I believed it to be a B but not sur
old
02-27-2006 09:39:16
Heres the deal, I picked up an Allis tractor that I was sure it was a B but now don't think it is. The steering is sort of funny looking to me to be a B. The steering arm is off the left side and the rod run down the left side. I can't make out the numbers well but does this sound like its a C??
Thanks
steve(ill)
02-27-2006 20:37:16
 Re: Ok what is it, I believed it to be a B but not in reply to old, 02-27-2006 09:39:16
the photo is a C steering arm. for the back end, a B is about 54-58 inches wide outside to outside tire. a C is about a foot wider or 70 inches outside. B and C have teh same motor, radiator, hood , transmission, etc. B is wide fron, C is normally narrow. C has 6 inch wider axle on each side rear.
ed in cny
02-27-2006 15:52:07
I went and took a look at the picture and the unit's a C. If the tractor has the narrow front end then it's for sure. The funny thing about the B and C is that most parts were exchangable. You may have the narrow front but the rear end could be a B with the B serial #. From what I see in the picture the front is narrow and with the rod it leads me to believe you have a C. Good luck with it.
Dakota Dave
02-27-2006 14:57:16
Thats a C
Texas Denny
02-27-2006 14:55:08
Old, it looks exactly like my C. But it could still be a B with a C front end. The serial number is on the transmission directly toward the rear of the shift pattern. It will start with a C if it is a C.
old
02-27-2006 15:57:00
 Re: Ok what is it, I believed it to be a B but not in reply to Texas Denny, 02-27-2006 14:55:08
That was part of my problem I couldn't really see the numbers well. There is what looks like it might be a C there but wasn't for sure. To bad theres only enough of it left to be a good parts tractor
Texas Denny
02-27-2006 14:28:08
Could you put a picture of the left side in Tractor Photos?
old
02-27-2006 14:48:19
 Re: Ok what is it, I believed it to be a B but not in reply to Texas Denny, 02-27-2006 14:28:08
I'll do that right now but the one I have of the left isn't real good
Stan(PA)
02-27-2006 12:44:31
I was thinking the serial number on the transmission started with either B or C. I"ve been wrong before....Stan
Joe(TX)
02-27-2006 10:23:53
Both had the steering arm on the left. Th C was turned up at the steering box and the A was turned down. The C had longer axle tubes than the B. The B"s all had wide front axles.
