Tranny Fluid in D17
mike
08-10-1999 05:31:57
Hi, can you guys tell me what to add for tranny fluid in a 58 D-17? I have to add some and am not sure what they use for the tranny.
thank you
micheal
Rick
08-10-1999 06:48:59
 Re: tranny Fluid in D17 in reply to mike, 08-10-1999 05:31:57
Most people use a universal tractor fluid. It is called hy-tran or other similar names.It can be bought at most Walmarts, Autozone, TSC, etc...It comes in 2.5 and 5 gallon containers. Make sure you check the fluid level with the lift arms fully extended in the up position.
Adam Brannick
04-10-2001 17:51:55
 Re: Re: tranny Fluid in D17 in reply to Rick, 08-10-1999 06:48:59
I was wondering if you could attach front loader to a D-17 allis chalmers and have live hydralics from the tractor itself without attaching any other pumps.
Thanks Adam Brannick
Frank
08-11-1999 21:13:54
Rick, The lift arms want to be down when fluid is checked Frank,NEO
mike
08-10-1999 07:42:34
Thank you,
So the Tranny and the hydraulics use the same sump (same fluid) is this correct? I was not sure if it was a common sump or seperate for the hyd. and for the transmission.
thank you again.
Micheal
Rick
08-10-1999 10:01:44
 Re: Re: Re: tranny Fluid in D17 in reply to mike, 08-10-1999 07:42:34
The hydrualic system is separate from the trans. The hyd filler is in front of the trans on the right side. The trans filler is on top of the trans by the gearshift. It's easier to by one kind of fluid than two.
mike
08-10-1999 10:11:48
 Re: Re: Re: Re: tranny Fluid in D17 in reply to Rick, 08-10-1999 10:01:44
Thank you, Rick
I appreciate the quick response and the valuable info.
Thanks,
micheal
