Allis B Brake Pins Frozen
oldallisb
02-25-2006 11:10:41
Greetings,
While I had things apart for painting I decided to go ahead and replace the brake bands on my 47 Allis B. The left one came off fine but on the right one both pins that the bands pivot on are frozen into the axle housing ... REALLY tight. Any tips from someone who's been there, done that, on getting these out? Heat? Plenty of liquid wrench? Prayer?
thanks,
Bill
oldallisb
02-26-2006 06:08:40
 Re: Allis B Brake Pins Frozen in reply to oldallisb, 02-25-2006 11:10:41
Thanks for the tips guys. I"m going to try the drill trick, I think driving them out is the only thing that"s going to work.
Texas Denny
02-25-2006 16:30:21
I used a drill and opened the casting from the back side so I could use a punch to drive them out. Pretty easy to do.
den/southern illinois
02-25-2006 15:46:14
I had some I could not get out of a C. I drilled a 1/4 inch hole from the inside thru the casting. I could put some PB Blaster in from the other end and also tap the pin in and drive it out with a punch. Worked well. You can always use to body putty to make the holes go away when done. Den
TractorMike
02-25-2006 11:55:48
Bill, You gotta use a lot of liquid wrench, PB blaster, WD-40 or whatever else you can find, Some heat wouldn"t hurt. I also used a ballpeen hamer and small bolt and beat on it for day"s, Finally came out after about 2 weeks or so, cna"t rember. Also a little prayer wouldn"t hurt. Hope this helps, TractorMike
K5ody
02-27-2006 07:51:08
 Re: Allis B Brake Pins Frozen in reply to TractorMike, 02-25-2006 11:55:48
Try a product called Kroil from Kano Labs. I discovered it recently and ordered some from their website (you can't buy it in stores). It's reasonably priced and works miricles or freeing up frozen parts/bolts.
Dale
