WD vs. WD 45
KRUSS
02-24-2006 13:34:37
I am an IH collector/restorer/addict. But having said that I remember a very good Allis my grandfather had. I am guessing it was made sometime between 1945 and 1955. It had the Allis 2 point hitch. Other things I sort of remember are: you sat offset to the right, had both hand and foot clutch (I do remember having it explained to me in no uncertain terms how that was supposed to work), I also remember a feature called a traction booster. I remember it as a nice tractor to drive. Can anyone clue me in to whether i am talking about a WD or a WD 45. I think if I saw a good picture of both I would know the answer. Thanks
ricedaddy
02-24-2006 16:51:14
 Re: WD vs. WD 45 in reply to KRUSS, 02-24-2006 13:34:37
How does the traction booster gauges work?
JMS/MN
02-25-2006 08:23:06
 Re: WD vs. WD 45 in reply to ricedaddy, 02-24-2006 16:51:14
Traction Booster is a weight transfer system to transfer weight of a mounted (not pull type) implement on an as-needed basis. It senses wheel slippage and slightly raises the implement, creating down pressure on the rear wheels. The large spring above the snap coupler, mechanically linked to the hydraulic valve, is the sensing device. The gauge is linked to the valve by a pressure line and shows relative amount of weight being added. When the lift control lever is completely lowered, the implement lowers and there is no weight transfer. As the lever is partially raised, the transfer system starts to work; the higher the setting, the more transfer, but also more variation in implement working depth. With the lever completely raised, the guage should be maxxed out, since the entire weight of the implement is on the tractor. Screws A B C D on the pump and valve need to be adjusted properly for the system to work. Linkage between the spring and valve needs to be set properly.
John (MO)
02-24-2006 13:59:24
Many who seem to think they ar experts can't tell one from the other. The WD was made from 1948 into 1953
The WD45 replaced the WD in 1953 starting with serial #146607.
The WD engine had a large removable plate on the side of the block. The WD45 engine did not have a removable plate but rather was solid.
WD45's all had curved gear shifter levers, the transmission gears were different too but of course you can see them without some wrenching.
WD's had straight gear shift levers up until the last year or so that they were made.
Of course the WD45 had a different crank shaft and pistons, but again that's not a visable difference.
I believe all WD45's came with traction booster gauges, some WD's had them and others had them added.
Snap coupler hitches became standard on WD45 with serial #151381. They had been optional for quite some time before that and have been added to lots and lots of tractors in the years since.
The sheet metal is the same on the WD45 as it was on the WD.
Serial number guide is on the left side of this page.
Aaron SEIA
02-25-2006 14:26:41
 Re: WD vs. WD 45 in reply to John (MO), 02-24-2006 13:59:24
One thing about the snap coupler, and correct me if I'm wrong. The bell UNDER the tractor is the snap coupler. That was started with the WD45, I think. The lift arm setup and the LIFT LATCHES (which many people think are snap couplers) were original to the WD's. So...your grandpa could have had a WD. For a while I owned a WD pickup plow that didn't have the snap coupler ring. I have snice switched my WD over to a 45 crank, head, carb, air cleaner, and added a snap coupler. Long story short, buy either one and I doubt anyone will know the difference. I have noticed that WD's will sell for a bit less, but I'd venture to guess that almost all of them are essentially WD45's from the flywheel forward.
Aaron SEIA
BDT in Minnesota
02-25-2006 19:54:48
 Re: WD vs. WD 45 in reply to Aaron SEIA, 02-25-2006 14:26:41
The WD has a 201cid engine, the WD45 has 226cid; due to a crankshaft with a longer stroke...the last few WD models produced (1953) came with the "WD45" transmission; which has the curved shift lever..The snap coupler could be ordered on the WD as optional equipment, so can be found on either tractor... Also, if the tractor has a radiator shutter in front of the radiator, it is a WD,I'm not sure when the shutter was deleted on WD production, but WD45s don't have shutters ....Driving the two tractors was quite a difference. the WD45 ran alot quieter due to the improved transmission, and had alot more power.
Texas Denny
02-25-2006 07:22:36
John, this is a very, very complete answer. The question is repeated often on this board as people come and go. Your response should be in the menu at the left!
KRUSS
02-25-2006 11:43:17
 Re: WD vs. WD 45 in reply to Texas Denny, 02-25-2006 07:22:36
Thanks. I think that tells me that the tractor I remember (and will look for one of, some day) is a WD45.
