Small AC crawler conversion ?
Jon Hagen
02-23-2006 18:56:27
Years ago my uncle had a small AC crawler,I don't remember any identifying numbers on the tin work,but it had several repaints. It appeared to be more or less a WD45 fitted with track undercarriage. To steer,it had hand levers connected to the brakes. trans appeared to be WD45. I don't remember if the rear axle had tractor style drop boxes or not,I think it did. It had a live hydraulic pump and quite a heavy front end loader. The engine had a pto style clutch/bellhousing unit with foot operated clutch. The exposed clutch shaft coupled to the trans input shaft using a sprocket and double chain coupler like Oliver used on a lot of tractors. The framework that attached the tracked undercarriage to the tractor was mostly welded steel pipe,not home shop cobbled,looked to be a factory job.
Did Linderman or some other outfit do crawler conversions to make these machines ? It was an interesting little rig and I have never seen another like it. TIA
