Hurst
02-23-2006 17:18:15
Re: Longevity Question in reply to rboulware, 02-23-2006 11:17:22
I forgot to say that allis had the best cast parts of any tractor company out there. They did much more research on their cast metal material than JD ever did. You are talking about the same company who powers a lot of Las Vegas with their turbines in the Hoover Dam. Allis was in no way a tractor behind its time and low in quality. They were straight forward, strong built, and built to last. I am pretty sure that the D19 can last over 5000 hours without an engine overhaul if it is used fairly often, oil is changed, and it is not abused. I will admit that I am partial to allis, but in this case, if the rough tractor costs more than the nicely redone tractor, then I would go with the nicely redone in most cases. Resale on the 4010 may be higher than the D19, but to get anything good for resale, you will have to fix her up quite a bit by the sound of it. A good paint job alone can run over 1000 dollars easily. Best thing to do, go to the place with the 4010, drive it around, see if they will let you test it out in the field. Then go to the place with the D19 gas, do the same, drive it around, try to get it out in the field some. Then after that, if none of them are leaking, showing any signs of future problems or have any problems, pick the one that you felt drove the best, the one that you would want to sit on for how ever many hours a day you will be sitting on it. That is the important thing. I would never buy a tractor that I have not been able to drive. I want to make sure I will be comfortable. With that said, make sure everything like the seat, pedals, steering wheel, are all in good shape or else you won't be able to get a good idea of which one you like better. That is my best advice. I could go on saying reasons allis would be a better choice in my opinion, and someone else could come right back and say why deere is better and rip me to shreds, so the only way I can help you choose is to tell you it is time for a test drive. You don't buy a car without a test drive, why buy a tractor without one. Chances are, once you buy it, you will be stuck with it for a while unless there are some avid antique tractor collectors in your area. The market doesn't seem to be up enough for people to be buying these tractors right now unless they are doing it for a hobby. Good luck and take em for a spin. Let me know what you think of each of them. Also, try the allischalmer(dot)com forum for questions about the D19. There are people over there that own/have owned both a D19 and some deeres and they will be able to give you a straight forward answer. Also, what are you planning on doing with the tractor? Hurst
