allis chalmers CA wiring diagram ...?
Rick Lemro
02-21-2006 17:38:59
Does anybody have a picture of the Allis Chalmers CA wiring diagram (year 1954).I need it to show the change from a 6 volt to 12 volt push pull starter.
Kent of SW MO
02-22-2006 06:14:27
 Re: allis chalmers CA wiring diagram ...? in reply to Rick Lemro, 02-21-2006 17:38:59
You do not need to change the starter. A 6 volt starter will work ok on 12 volts. You also do not need to worry about the starter when you change ground polarity. The starter does not care if the ground is positive or negative.
Kent
steve(ill)
02-21-2006 19:21:15
duey has a good setup that shows generic wiring for a 12 volt conversion. determine if you are using a generator or alternator, and if you have a distributor, then ask specific questions for more help.
http://dueyschutter.freeservers.com/photo3.html
