GLEANER E ENGINE
WCPULLER
02-19-2006 15:59:44
I WAS WONDERING THE BORED AND STROKE OF AN GLEANER E ENGINE. THANKS
slowsmoke
03-04-2006 07:57:53
 Re: GLEANER E ENGINE in reply to WCPULLER, 02-19-2006 15:59:44
they just did one in the "HOOK". I think he went 4.6 x 6" stroke
Kent of SW MO
02-20-2006 09:58:48
Gleaner A's have a 6 cylinder power unit but it is 230 cid. C, C-II ,and G's use the 6 cylinder 262 cid power unit. The starters are the same for the 230 and 262 power units.
Kent
D17JIM
02-20-2006 04:25:35
The two E's we owned were both 226-4cylinder engines.
j105
02-19-2006 16:44:31
gleaner E and E3 had 226 cid gas engines. bore 4in. stroke 4.5in.
1206SWMO
02-19-2006 19:55:19
 Re: GLEANER E ENGINE in reply to j105, 02-19-2006 16:44:31
You are correct.Its a 4 cyl 226 CI with 4" bore and 4.5" stroke.
My Dad bought a new 1966 E Gleaner.
BCnT
02-19-2006 18:34:22
i was under the impression the E's had a 6 cylinder gas engine with 262 displacement...supposedly everybody uses them to replace the diesel 262.
Tramway Guy
02-20-2006 11:30:35
 Re: GLEANER E ENGINE in reply to BCnT, 02-19-2006 18:34:22
The C2 combine used a 262 gas engine. Maybe some others did as well. The C2 diesel was the 262 turbodiesel, same as the D19.
1206SWMO
02-19-2006 19:58:21
All E's were 226 4 cyl..A's and G's were 6 cylinders.
BCnT
02-20-2006 08:31:48
 Re: GLEANER E ENGINE in reply to 1206SWMO, 02-19-2006 19:58:21
thanx for settin me straight...glad i didnt bid on that E for a replacement engine for that POS diesel
BCnT
02-19-2006 16:04:40
pretty sure its same as diesel 262...3&9/16 bore by 4&3/8 stroke
WCPULLER
02-19-2006 16:07:40
 Re: GLEANER E ENGINE in reply to BCnT, 02-19-2006 16:04:40
I WAS WONDERING HOW BIG OF A BORE I CAN GET AND WHAT KIND OF PISTONS I CAN PUT IN IT.. THANKS
