OILS TO USE IN D17 ALLIS CHALMERS ?
KELLY ONEAL
02-19-2006 12:02:04
STARTING AT THE ENGINE, I KNOW WHAT TYPE OF OIL THERE. GOING TOWARD THE REAR OF TRACTOR SECOND OIL COMPARTMENT, WHAT TYPE OF OIL? THE COMPARTMENT IN FLOOR BOARD, WHAT TYPE OF OIL? THANKS IN ADVANCE. PHONE 1-580-243-8820 CELL HOME 1-580-5427
steve(ill)
02-20-2006 16:00:48
 Re: OILS TO USE IN D17 ALLIS CHALMERS ? in reply to KELLY ONEAL, 02-19-2006 12:02:04
because of the higher loads on the D17 transmission, it normally was filled with 90 wt gear lube. the universal hytrans is used in the hydraulics area. you could use the hytrans in the transmission if not doing heavy field work everyday.
Art DeJager
02-20-2006 10:56:04
Don't use 90W oil in the transmission. Use hydraulic oil. Don't ask me how I know...
TexasAllis
02-20-2006 06:03:57
Kelly,
If I am reading your terminology correctly the second compartment located in the torque tube should be the hydraulics. That takes trans/hydraulic fluid. Depending on the series of D-17 you have there may be one or two fill places in the "floor". If you have one filler I would run 90wt. That lubes the trans and rear gears. If you have two fillers one is the trans and rear gears the other is the power director clutch which takes trans/hyd fluid. I suggest you get a manual before you start servicing the tractor. Tractor supply usually has the books.
Good luck
Worth Golightly
