1939 B
maricopa
02-18-2006 20:01:07
I want to replace the bolts that hold the draw bar (old ones are stripped) and I can't match up. 1/2" is too small and 5/8" is too big. I haven't seen 9/16" bolts and wonder if that is indeed what I need.
chalmersbob
02-21-2006 18:53:53
 Re: 1939 B in reply to maricopa, 02-18-2006 20:01:07
the holes on my 40 b were stripped and i drilled them out and put in helicoils for 1/2" bolts. worked great. BOB
Tom Davison, (PA)
02-19-2006 07:25:28
Steve is correct. The early B's had 1/2 inch threads for the drawbar. My 39 has 1/2 bolts. In the later parts books, it shows bushings to use on the bolts and on the pins of the clamp if you have a newer drawbar and want to install it on an early B
Texas Denny
02-18-2006 20:20:29
Sounds like a possible thread problem. These should be 5/8 bolts. Do you have a regular tap and a bottom tap? I'd clean those threads as good as you can with a dental pick and then try the regular tap. This is a shallow tapped hole so you won't be able to fully clean the threads with the regular tap and may need a bottom tap to get them.
Texas Denny
02-18-2006 20:23:34
 Re: 1939 B in reply to Texas Denny, 02-18-2006 20:20:29
Based on Steve's input, disregard mine.
steve(ill)
02-18-2006 20:17:42
if i am not mistaken, the original B had 1/2 inch bolts the first couple years, then changed to 5/8 about 1940. i would guess the holes are wollowed out. you might be able to retap with a 9/16 tap and install those. yes, there are 9/16 bolts. try local auto shop like Auto Zone or NAPA, also some farm stores.--- some guys install thread inserts to go back to original size. i would suggest you tap out to 9/16 and then loctite new bolts in the holes/
Texas Denny
02-18-2006 20:22:42
 Re: 1939 B in reply to steve(ill), 02-18-2006 20:17:42
Whopps! That is news to me that they were half inch in the early years. What about using a helicoil?
