Adding Hydrolics
J Henkle
02-17-2006 09:14:59
Is there a pump/kit that is easily adapted a D17 III? Would like to end up with 2 or 3 spools.
Currently I can not run the 3pt and single spool at the same time. When the spool is hooked up, the 3pt will not lift. Popping pressure valve, yes???
Anyway would love to hear my options... Jody
JMS/MN
02-17-2006 18:45:48
 Re: Adding Hydrolics in reply to J Henkle, 02-17-2006 09:14:59
Your Series III should have a machined, drilled, tapped surface on the front pulley, where you can bolt on a factory shaft which comes out in front of the radiator, where you mount a factory pump. Gives you a source for independent hydraulics.
