Hi Vince, If your B is still a 6 volt system, then I would recommend either 2 gauge, or larger, cables. If it has been converted to 12 volt, you could go down to 4 gauge. As for the wires, I recommend 10 gauge for the charge wire coming from the generator (alternator) to the amp gauge and then to the battery. 12 gauge should work fine for everything else. It's always better to have too big wires than too small wires. You may check e-bay. There is someone there who occasionally sells wiring harnesses for B's and C's. Check this site to see if they carry those 3-position switches. I have seen those 3-position resistor switches sometimes, but what I've seen has always been really pricey. Keep your eye on ebay. Otherwise, you may be looking at converting to a voltage regulator. Fun Projects makes a solid-state voltage regulator designed to replace the cut-out switches on Ford 9N's and 2N's. The neat thing about it is that it behaves as a true regulator and you won't need the resistor switch for the lights. You can set the third brush at the highest charge you could need (low battery with lights on, perhaps) and it will regulate the amperage as needed. It directly replaces the cut-out (which many of the new cut-outs don't cut out). It only works on 6-volt positive ground systems, too. I can vouch for them...I put one on a Ford 2N and it worked great. Downside, they are about $70. Good luck, RandyN
