D19
Kip2
02-14-2006 15:42:06
I think I am gonna start looking for a D19 Diesel I have never owned an Allis nor has the farm I grew up own (live on) ever had one on it I grew up around ford and IH and own a few I bought a copy of Norm Swinfords book Allis Chalmers Farm Equipment 1914-1985 I think the D19 would be a good general purpose tractor plowing,disking,etc. what do yall think Thanks
C.B. McCune
02-16-2006 06:52:02
 Re: D19 in reply to Kip2, 02-14-2006 15:42:06
I own a D19 and like it. When I purchased the tractor the turbo was froze up- took a little time ot find a charger that would work with the exhaust hole but found a Garrett charger and it works great. The transmission does not jump out of gear. Would make a good plow/disc tractor. We used it mainly to grind feed, pull a double wheel rake and a 9 ft discbine to mow hay. My family retired from farming in 2002 so now I take it to a couple shows and parades a year and mow about 10 acres with a brush cutter. All around it is a good tractor.
Brad Wright of MO
02-15-2006 13:49:23
I think the D-19 is a great tractor. The only thing I dont like about the D series is the seat sits on a hump and if your a short guy its not easy to push the pedals fully. I noticed you talked about discing. It is good for that. Always with the hand clutch it makes it easier for loader work. I strongly reccomend the D-19 for anything. Also on that tractor I have never once had problems with it jumping out of gear.
John (MO)
02-15-2006 05:59:42
The D-19 is a great tractor. You can"t get more HP for the $$. The diesel does need to be taken care of or the heads can crack. You also need to check the transmission to make sure it doesn"t jump out of gear. You have 2 way hydraulics with the D-19"s and can have 2 sets of remotes with most of them. They came from the factory with either a snap coupler or 3 point, so you can convert a snap coupler to 3 point with AC parts and not have to use a conversion. You can get a D-19 a lot cheaper than you can a D-17. Some people think they are too big for their needs, and I guess in a few cases they are. I don"t need a tractor with the HP of a D-19, but it"s sure nice to have, and the size hasn"t given me any problems except in hauling. It won"t fit on my trailer. The gas tractor uses a little more gas than the 4 cylinder tractors, but it actually uses less per hp. I suppose the same is true of the diesel particularly because of the turbo. I would expect to be able to get a D-19 diesel for around $3000, while I think you"ll pay at least $1000 more for a D-17 diesel especially if it is a series 4. D-19"s are a very well kept secret.
klf
02-14-2006 16:28:32
Would you take the D 17 gas over the 175 with the 248 Perkins diesel?
Hurst
02-14-2006 16:40:45
 Re: D19 in reply to klf, 02-14-2006 16:28:32
If you are asking me, I would take the 175, but not by much. The 170 and 175 used a longer gear shift lever than the d series, so if they were grinded into gear, it would do quite a bit more damage due to the extra leverage. I was just thinking he wanted to stay in the d series. Although I will say from what I have heard a D17 gasser is not a bad tractor at all. All I have had was a series 4 diesel, and the diesel D series are going to start to get pricy as they are becoming a favorite of orange collectors.
Hurst
Hurst
02-14-2006 16:02:32
D19 diesel needs someone who is careful when operating it. The 262 budas can begin to have head problems if overheated and/or not cooled down properly. I am not sure how many acres you have, but I would look for a D17 series 4 gas with a 3pt. That would be a much better tractor for a hobby farmer, it has much better hydraulics and is a good reliable tractor. The 226 gas is a good gas motor and is great on fuel. D19 is an awful big tractor, just something to be aware of. How many acres are you taking care of?
Hurst
