? D 19 going to look at one
Punchie
02-14-2006 03:16:21
Hi Forum
I'm use to wd, wd-45's .
But I'm going to look at a D19 Gas.
Is there any thing I should double check etc. while I'm driving and looking at it?
Thanks !! Teddy
Brad Wright of MO
02-14-2006 15:09:42
 Re: ? D 19 going to look at one in reply to Punchie, 02-14-2006 03:16:21
If you use the tractor right it will not jump out of gear. All you have to do is be patient with the gearshift. If you start to move in to gear and it makes a terrible grinding noise. Turn the tractor throttle down to a slow idle and try it again in a few seconds. You cant force it that will break things. They arent powershift tractors. Be patient with them.
John (MO)
02-15-2006 06:11:44
 Re: ? D 19 going to look at one in reply to Brad Wright of MO, 02-14-2006 15:09:42
It's the people that have used a tractor before me that cause me to worry about the tractor jumping out of gear. That's why you have to check carefully BEFORE you buy.
old
02-14-2006 07:45:42
As John has said one of the problem areas on them is in the tranny.
John (MO)
02-14-2006 06:09:13
Make sure it does not jump out of gear when going down hill. FIRST... Make sure brakes WORK! Otherwise it can be a lot like an olympic luge (sp?) ride... only with a really big heavy sled.
