Front tires on a C Allis Chalmers
willey-65
02-13-2006 16:47:17
Does anyone know If 5.00 X 15 Tires will work on a Allis "C" It now has 4.00 X 15 Thanks.
RandyN
02-13-2006 16:54:09
 Re: Front tires on a C Allis Chalmers in reply to willey-65, 02-13-2006 16:47:17
Hi willey,
Yup, 5.00 x 15's will work just fine.
RandyN
Kip[UT]
02-13-2006 16:53:56
If wide front the 500s work great. If tricycle stick
w/ the 400x15.
Willey-65
02-13-2006 17:19:53
 Re: Front tires on a C Allis Chalmers in reply to Kip[UT], 02-13-2006 16:53:56
Can you tell me the draw back on the 5.00 X 15 ? Thanks Willey
Dick L
02-13-2006 18:15:37
 Re: Front tires on a C Allis Chalmers in reply to Willey-65, 02-13-2006 17:19:53
Unless you place spacers behind the wheels the tires will rub at the bottom. I bought the 500X 15"s for the front of my C and filled them with fluid. They work as long as you start all the lug bolts and tighten the bottom wheel bolts last. I switched and put the CA narrow front on my C as it has a wider width between hubs.
