live pto,who was first
d masters
02-13-2006 10:30:05
who was first with liv pto and cabs?
Texas Denny
02-15-2006 07:19:43
 Re: live pto,who was first in reply to d masters, 02-13-2006 10:30:05
D masters, did a little hunting. I believe the first tractor that could stop forward motion without interupting was the Cockshutt 30. It was introduced in 1946. It was tested in Nebraska in 1947. The 30 had live power - a separate clutch to energize the PTO which was driven directly off the crankshaft. The Oliver version was nearly identical and was introduced in 1948 with the 77 and 88. Allis also introduced a different version in 1948 with the WD whichused a common clutch for energizing forward motion and the PTO and had a second clutch which stopped forward motion without interupting the PTO. Allis Chalmers CA came out with a version which used a clutch on one of the axels. That was in 1950. Massey harris used this same method in the 44 Special in 1953 (may have been on the 33 also). John Deere hit the street in 1952 with the 50 and 60 series. I believe the Super M in 1952 had live power but I don't know how they did it. For sure it was included in the number series (300 and 400).
Kent of SW MO
02-14-2006 06:20:42
I think Case was first with a cab. Remember the Comfort Tractors of the thirties. Very collectable now.
Kent
Kent of SW MO
02-16-2006 05:21:57
 Re: live pto,who was first in reply to Kent of SW MO, 02-14-2006 06:20:42
Sorry to the MM guys about the comfort tractors. CHAFT disease kick in.
Kent
Texas Denny
02-15-2006 06:51:30
The comfort tractors were from Minneapolis Moline. They had them in both the model R and the model U. The U was called the UDLX. Can't remeber if the cabbed R had a special designation. A restored UDLX is the most expensive tractor built before 1950. A really nice one will bring in the $50,000 to $100,000 range!
INcase
02-15-2006 04:48:09
Cockshut was 1st (don't know what year). Olivers were close and had a very similar design. Case for sure at least around the mid 50's with the 400, and I think a model or so before that (??). AC was into the 60's with the series III maybe????
John (MO)
02-14-2006 06:19:37
Denny got the PTO part, it was Oliver.
MM had the first cab. Sure wish I had a strong half dozen of them in the barn to carry me through the retirement years.
Texas Denny
02-13-2006 13:39:23
Cockshutt was first. I believe it was 1947. Oliver came out with it in 1948. Allis did also. John Deere came with it in their number series. I think Case and MM came around 53 as did Farmall.
old
02-13-2006 10:48:18
As far as live PTO it was either Oliver or Cochsutte
Bill(Wis)
02-15-2006 06:08:14
 Re: live pto,who was first in reply to old, 02-13-2006 10:48:18
Please don't shoot at me for saying this. It is a technical point, but I believe Oliver/Cockshutt was referred to as "independent PTO" because it had a seperate clutch to engage/disengage the PTO completely independent of tractor movement. All of the "live PTOs" stopped the tractor first and left the PTO running . Or, started the PTO first and then got the tractor moving. "Live" involved either two clutches as with the AC's starting with the WD or a two stage clutch as with Ford. I don't remember what Deere was like. I never drove a numbered Deere. Only lettered ones.
old
02-15-2006 07:23:52
 Re: live pto,who was first in reply to Bill(Wis), 02-15-2006 06:08:14
Well true live PTO is indepentent of the clutch but either one is called live PTO theres just a few way to get it but all of them are live PTO.
