starter for WD
Che
02-13-2006 09:42:05
My ignorance showing again...
How do you change the starter on a WD? I don't see how the darn thing is connected! Are there bolts that hold it in place?
Thanks in advance!
old
02-13-2006 09:48:19
 Re: starter for WD in reply to Che, 02-13-2006 09:42:05
Theres a bolt that has a lock nut on it going down at about a 45 degree angle. You loosen the lock nut and then pull to bolt and the starter will slide out. If you look at the end of the bolt it has a bevel which fits on a hole on the starter, thats all that hold it in. Once you have the bolt out you may have to turn the starter a little both way to get it to slide out. The bolt is about center of the tractor
