D 15 Series II Steering coupler
Henry M
02-12-2006 15:37:07
I got a lot of slop in the steering where the coupler is that connects the shaft to the power steering valve up front. A lot of it is the roll pin that holds the coupler in place.
Now since this pin goes thru the shaft on what must be the control valve, I am wondering/trying to figure out a way to knock it out without stressing something in the steering valve assembley or the shaft going into the valve.
I am still waiting on my service manual to come in, but nothing beats advice from the experienced.
Thanx
BCnT
02-13-2006 08:51:44
 Re: D 15 Series II Steering coupler in reply to Henry M, 02-12-2006 15:37:07
if ya got room you could make a pin press out of a c clamp by welding a bolt same diameter of roll pin to swivel portion of clamp and using a deep socket for receiver on other end
henry M
02-13-2006 09:55:57
 Re: D 15 Series II Steering coupler in reply to BCnT, 02-13-2006 08:51:44
Good Idea BC, when it gets above freezing outthere, I will give that one a try if nothing else pops into mind.
