AC/ G
frito
02-12-2006 09:41:43
Hey guys, I need help. I'm rebuilding a Continental N62 engine for an A/C G. I got the engine together and started it. It ran good, but no oil pressure. I pulled the engine, checked oil pan, pickup tube is in oil. I blew out all the oil lines, all clean, pulled pump and it was dry. I tried the pump on the bench and it seems to be moving oil from one side to the other.I used 30 wt oil.Any ideas what to do next? Thanks for any ideas.
frito
02-13-2006 09:36:44
 Re: AC/ G in reply to frito, 02-12-2006 09:41:43
Hey guys, thanks for the help I did what you said and primed the oil pump. Got plenty of oil pressure now. Thanks again.
den/southern Illinois
02-12-2006 14:13:58
Another possibility is the oil filter. I"m sure that you put a new one on it and a year or so ago there were some filters made that were not right for the AC"s. I can"t tell you which ones but my brother"s D 14 lost oil pressure after an oil adn filter change. Gavehim one of my AGCO filters and he had oil pressure again. Of course the priming of the oil system as suggested may be the solution if you already have the correct filter. Den
Dick L
02-12-2006 11:47:42
If it was dry when you took it apart after it was run it would mean you didnt prime the pump before you started the engine the first time. You will need to fill the oild lines from the gage. A hand held squirt can is a good choice and remove the gage and squirt all the oil that the pipes will take. Turn the engine over by hand and fill again.
