AC C VALVES
gary case
02-12-2006 07:50:44
Well i got my Allis C back together for the second time put the starter in and cranked her over about 3 turns and it sat there and purred, then it quit. I CHANGED the rocker arm so i thought i goofed that up. I timed the valves the way the book said and fired it up and ran great. But, it sounds a little noisey to me. sometimes it'll sit there and run for an hr. then just cough, then run, then quit. Fires right back up and runs good again. it coughs under power and seems not to have much power. Just wondering if that's the valve adj. or gas, or electric problem. I know it could be any of the 3. where would you's start? THANX GARY
Dick L
02-12-2006 11:52:04
 Re: AC C VALVES in reply to gary case , 02-12-2006 07:50:44
Good on you for getting her up and running. Fuel is most likly your problem with a slight blockage up line from the carburator.
