Sticking Valves on WD 45
Hoenes
02-12-2006 06:05:06
I have a 1955 WD 45 that runs and pulls great. Once in a while though, it developes a horrible miss. I have eliminated any fuel or electric problems. If I take the air intake hose loose at the carb and spray in WD-40 or a light mist of fuel oil, it straightens out. When the mist runs out, the horrible miss comes back. Is there any easy solution other than a complete overhall? {I read on previous pages that a top end without a ring overhall usually backfires!}
Dave NE IA
02-15-2006 14:31:02
 Re: Sticking Valves on WD 45 in reply to Hoenes, 02-12-2006 06:05:06
Ex-wives grandpa said the old F-20 had a spell once in a while. They just pumped kerosene in the carb wile running at a fast idle till she would almost kill then do it several times. He also mentioned dumping oil in the gas tank. He said it was stupid of his son to ever think you could burn gas all day instead of disalant. Dave NE IA
BushogPapa
02-13-2006 09:27:32
Get it running and warm it up good....
Then, loosen the small plug in the intake runner. Have an oilcan (pump-type) ready with clean, full, engine oil... Have a piece of hose pushed over the tip, to seal against the intake. With the engine running at a good fast Idle, carefully pull the plug and insert the oilcan tip in the hole. Pump in the oil as fast as the engine will take it without quitting.. Use the entire contents of the oilcan. DO THIS OUTSIDE....!!!!! !!! It WILL smoke a bunch, but will eliminate sticking valves.. We do this every year on our WD-45's and JD "B"'s. Never had a problem since we started doing this... Have fun..!! Ron..
Texas Denny
02-12-2006 06:28:26
I had a very similar problem on an M Farmall that I used to own. I pulled the head and removed every valve. I thoroughly cleaned every stem and guide. There was kind of a lacquor on both that made it difficult to get them out. After cleaning, I did lap the valves a bit to be sure that they were making full circle contact and then, I reassembled. Tractor ran great after that.
Friends told me they had had this experience when they used old gas (I remember a lot of old gas in my M when I got it). If your tractor is running as you say, it doesn't need an overhaul - just cleaning. And it won't affect it to have the head pulled and cleaned.
Contact Don Livingston at Rusty Acre (507-433-0073) for the head set of gaskets).
