massey harris 33
michael orefice
02-12-2006 05:04:57
Does anyone know if you can still get a clutch for a MH 33 tractor?
Texas Denny
02-12-2006 06:34:57
 Re: massey harris 33 in reply to michael orefice, 02-12-2006 05:04:57
You might have better success with this question on the Massey board.
I don't know if you can or not. I needed a rear seal for the engine on my 44 Special. It wasn't available so I had to make one.
Probably you could get by with just a clutch disk. Generally the clutch pressure plate and flywheel don't wear that much unless the clutch is used until the rivots come through. I'd guess the plate would be available. Maybe not on the pressure plate.
I've found a lot of old parts new from Rusty Acre (507-433-0073). If you are striking out, I'd start watching EBay. I think the 33 clutch and the 44, 44 special are all the same.
