B allis
bill1946
02-09-2006 16:34:28
im looking at a B allis need to no years it was proudced also whats the going price and hp of the tractor thank you
steve(ill)
02-09-2006 18:51:15
 Re: B allis in reply to bill1946, 02-09-2006 16:34:28
120,000 model B tractors built between 1938 and 1958. about 22 HP as mentioned. dont matter if it is older or newer, all about the same. mice to have electric start, foot brakes, and hydraulic pump mounted with PTO shaft. check those things out. If it runs and looks like crap it is about $600. Decent tractor, not restored is close to $1000. Dont sell too many over $1500. Nicely restored could be $2000, but few are looking for that.
lzybull
02-09-2006 18:28:46
hope this helps. Glenn
Allis Chalmers B Manufactured: 1938 - 1957
Total built: 120,783 Factory: West Allis, WI Cost: (US Dollars) $1500 (1957) Power: Drawbar (HP): 10, 15 later Belt (HP): 14, 19 later Plows: 1 (16-inch) Engine: Manufacturer: Allis-Chalmers Fuel: gasoline Cylinders: 4 Bore/Stroke (inches): 3.375x3.50 Displacement (ci): 125.3 Compression: 5.75:1 Rated RPMs: Torque (ft-lbs): Firing order: 1-2-4-3 Oil capacity (qts): 4 Spark plug gap: 0.035 Point gap: 0.020 Final engine, used from 1943 on, SN 64501 Engine: Manufacturer: Allis-Chalmers Fuel: gasoline Type: vertical I-head Cylinders: 4 Bore/Stroke (inches): 3.25x3.50 Displacement (ci): 116.1 Compression: Rated RPMs: 1400 Torque (ft-lbs): Firing order: Oil capacity (qts): Second engine, used until 1943, SN 64500 Engine: Manufacturer: Waukesha Fuel: gasoline Cylinders: 4 Bore/Stroke (inches): 3.00x4.00 Displacement (ci): 113 Compression: Rated RPMs: 1400 Torque (ft-lbs): Firing order: Oil capacity (qts): Original engine, used in 1937 on the first 96 tractors built Transmission: Type: sliding gear Forward: 3 Reverse: 1 Capacity: Fuel (Gal): 13 Cooling (Qt): 8 Power Take-off (PTO): Type: transmission Rear speed (RPM): 560 Tires: Ag front: 4.00-15 Ag rear: 10-24 Dimensions: Weight (pounds): 2,060 Wheelbase (inches): 74 Length (inches): 110 Width (inches): Height (inches): 63 Ground clearance (inches): Electrical: Battery volts: 6 Ground: Battery cold-cranking amps: Alternator amps: Nebraska Test: Test Number: 302 Test Date: May 1938 Engine: 116 ci gas Belt HP: 15.68 Drawbar HP: 12.97 Max pull (pounds): 1,473 Nebraska Test: Test Number: 439 Test Date: May 1950 Engine: 125 ci gas Belt HP: 22.3 Drawbar HP: 19.5 Max pull (pounds): 1,742 Serial Numbers: Location: On top of transmission case, behind shift lever 1938 97 1939 11800 1940 33502 1941 49721 1942 56782 1943 64501 1944 65502 1945 70210 1946 72265 1947 73370 1948 80556 1949 92295 1950 102393 1951 114527 1952 118674 1953 122310 1954 124201 1955 124711 1956 126497 1957 127186 1946 1001 (IB) 1947 1003 (IB) 1948 1010 (IB) 1949 1282 (IB) 1950 1556 (IB) 1951 1879 (IB) 1952 2219 (IB) 1953 2570 (IB)
old
02-09-2006 16:42:24
Around 22HP. Years not for sure but they where made around 1938 or 39 till some time in the 40s or 50s not sure when they started and stopped. Price depends on a lot of things, tires sheet metal etc. So it could be from around $200 for one in bad shape to up around $2000 restored.
