7000 oil pan
Hurst
02-08-2006 15:25:56
Will the oil pan off of a gleaner combine with a late 301 with the crank mounted oil pump work on the 301 in a 7000 with the crank mounted oil pump? Basically, I need to know if there are any differences in the oil pan for the tractor compared to the combine oil pan. I have found a used one for my 7000 that is a combine oil pan and need to know if it will be the same as the one on it now minus the crack and leak:). Thanks
Hurst
