B PTO box
Carroll Co FFA
02-06-2006 07:24:16
I am a high school student restoring a B.
Do I put 90 weight in the PTO gear box? If not what weight do I use and where do I fill it at on the tractor.
steve(ill)
02-06-2006 18:03:56
 Re: B PTO box in reply to Carroll Co FFA, 02-06-2006 07:24:16
the transmission, pto, steering and hydraulics are all in the same cavity. there is a 1 inch pipe plug by your left foot on the transmission. there are three 1/2 inch pipe plugs on the bottom,one under each cavity. total volumn is about 8 quarts. best oil today is universal hydraulic-transmission fluid or hytrans. you can get this at Farm Store or rural Wal Marts in 10-12 quart jugs. this is a new 20wt formulated oil for hydraulic pumps and trans gears- no foaming.
02-06-2006 09:05:20
The manual calls for 20 weight non detergent oil in the differential which supplies the hydraulics. The fill plug is in the housing behind the left footrest area.
