c allis steering sector
d masters
02-06-2006 06:23:38
anybody rebuild gemmer steering sectors for c allis chalmers,can a person use one off of e-gleaner?
Randy Norden
02-06-2006 14:12:07
 Re: c allis steering sector in reply to d masters, 02-06-2006 06:23:38
Hi,
I couldn't tell you if the steering sector from a Gleaner would work. I did find that some Jeeps used Gemmer steering boxes. I'm not sure if they are the same ones used on A-C tractors, but I'll bet they share common parts.
I can share with you that the seal for the cross shaft housing is National 472560N. The bearing cones for the worm shaft are Timken 5BC, but I got them from the AGCO dealer ship. Finally, I used an O-ring instead of a gasket between the cross shaft housing and the worm gear housing. It seems to work great.
Good luck,
RandyN
d masters
02-06-2006 16:33:48
 Re: c allis steering sector in reply to Randy Norden, 02-06-2006 14:12:07
thanks,will give a try
