D17 Brakes
J Henkle
02-06-2006 05:09:05
The manual says the final drive needs to be removed in order to service the pads. What kind of a job is that?
My left brake in pretty much non effective. I may live with it unless it is very straight forward.
Thanks, jh
JMS/MN
02-06-2006 07:44:24
 Re: D17 Brakes in reply to J Henkle, 02-06-2006 05:09:05
Have you taken the top cover off and adjusted the band?- might be all it needs. Otherwise it gets involved- you need to block the tractor, remove the wheel, and have a hoist or cherry picker to remove the final drive. Early D17 is like the WD45, band can be replaced without doing all that. Later ones had band and disc brakes- those you need to pull the finals.
