allis chalmers b
vman
02-05-2006 12:41:54
i bought a ac model b and not sure what spark plug number to use it is a 1939. and i need a water pump but they list two not sure which one to buy can anyone help please thanks vince
pat sublett
02-14-2006 11:11:20
 Re: allis chalmers b in reply to vman, 02-05-2006 12:41:54
The problem is current day fuel, I had problems with a ferguson 40. It would run for about a month on a set plugs. I have had the same plugs in it for 3 years now. I talked to a Champion rep. and he told me to use a plug with a higher heat range. The number on a Champion indicates heat range. Example: J19LM is hotter than J17LM. Use a J14 rather than a J8. It is important to use fuel stabalizer (such as Stabil)in any fuel that is subject to set over 60 days. I have a small engine shop and 90 + % of the problems I see are caused by bad fuel
jd4020
02-10-2006 06:19:49
Good info to know I put res plugs in my b and have been haveing problems with it miss fireing. I had the carb off and on all last year thinking it was a carb problem. i shoold have known that it might be the new plugs , PUT THEIR NEW...
gary case
02-07-2006 13:10:48
sooooo ooo!!!!! !!!!! !!!!! this means i better change my brand new wires and plugs. that's ok, i got them at auto zone. this time i'm going back to NAPA and stay there. going to take a picture of the plugs and cap. with there knowledge he'll able to give me a good choice in plug wires and plugs. How come we didn't know this before?
Kent of SW MO
02-06-2006 06:01:45
You could also use the Champion J-17LM or J-19LM which can be used in the place Of the J-8 in lawn mowers.
Kent
jeffalex2
02-06-2006 03:19:23
Champion J8's are OK, but, I like NGK B4's better. DONT use resistor plugs or resistor wires, you'll fry the mag coil, I guarantee it.
Terry DeBoer
02-05-2006 13:09:46
I am in the process of fixing up an Allic B. I replaced the old plugs with AC Delco R45.
Dick L
02-05-2006 15:27:12
 Re: allis chalmers b in reply to Terry DeBoer, 02-05-2006 13:09:46
R means resister in the R 45"s. Resister plugs are not the best choice. I bought a set and had no problems the first year. Started to have a miss problem and bought another set of the R 45"s still had a miss under power. Put in a set of Autolite 295"s and the miss was gone. I have now had problems with the Autolite"s just quiting on me. I have had good results the last two years by buying Champion J8"s buying them one in a package from the lawn mower parts display in the farm store"s. Lawn mower plug are not resister plugs. I am just guessing that the Champion plugs that are condemned here are resister plugs bought by the box.
