Level plugs on WD trans/rear end?
Dwayne TX
02-03-2006 21:29:34
I can find the drain and fill plugs for the hydraulics, transmission, rear end. Where are the level plugs mentioned in the manual, so I can make sure they're full?
Dwayne TX
02-04-2006 21:10:11
 Re: Level plugs on WD trans/rear end? in reply to Dwayne TX, 02-03-2006 21:29:34
Thanks for the info. Wish the manual had read that way. It makes it sound like there are other plugs. The final drives are the next to take apart, clean up, and refill.
Guyzoo
02-04-2006 16:54:46
Hydraulics: There should be a dip stick for the hydraulics. Keep to full mark
Trans/Diff: There is no level plugs. fill them completely
DON'T FORGET THE FINAL DRIVE PANS!!
HTH
