D15 gas running rough
gitoad
02-02-2006 14:02:33
Help! D15 gas started running rough last summer. I change and gapped the plugs to .025. I changed the pts, gapped them at .022 and changed the condenser. It idles fine, starts perfect but once it warms up runs rough with an occasional backfire when given her the gas. Carb adjustment seem ok as when I change them the tractor runs worse so I left them where they were when it was running fine. I have let it idle fast and pulled off each plug wire and each one makes a difference when pulled off. It runs worse as I put a load on it. Where do I head next?!!
gitoad
03-12-2006 12:57:46
 Re: D15 gas running rough in reply to gitoad, 02-02-2006 14:02:33
Put on a new distributor cap today. Starts right up but still does not run smooth under load. No longer back fires. When I pull off 3rd plug wire from the front at high idle engine does not run too much worse than when it is on. I have put penetrating oil into the plug hole, replaced the plug and it starts right up and burns the stuff out but no improvement. I am going to try atf as suggested with the idea it is a stuck valve. Is there a sure fire way to check? Maybe with a compression guage?? As always your guidance is appreciated!
Dan Musil
02-05-2006 08:34:25
You could have a valve sticking probably a ex.Try removing intake hose and squirt in some
atf with eng at hi idle,somtimes that works.
Arthur DeJager
02-04-2006 17:16:47
Make sure the centrifigal advance weights are operating properly and the springs are not broken (in the distributor). Check or replace the plug and coil wires. Make sure there are no restrictions in the fuel and air flows. Keep at it. You'll find it.
gitoad
02-05-2006 04:11:04
 Re: D15 gas running rough in reply to Arthur DeJager, 02-04-2006 17:16:47
I have had to order the distributor cap as the local parts stores do not carry ag parts. I appreciate all the replies! I will let you know how I make out when the cap comes!Does anyone know of a reliable place to send a carb(on another tractor) out to be rebuilt?
Kent of SW MO
02-03-2006 06:13:30
If a new cap and bug do not fix your problem try a new coil.
Kent
old
02-02-2006 15:39:52
Just to add to Texas, I agree it could be the cap but if you replace the cap also replace the rotor, either one can cause your problem. It could also be that the carb is running to lean which will also cause it to backfire. Open up the main jet a 1/2 turn at a time and then try it out, if you get to the point that you have black smoke then you have it open just a little to far.
Texas Denny
02-02-2006 14:41:12
It is like going through a swamp. Never know how deep the water is. You've done points (I think gap is 0.015" but 0.020" should work), plugs and condensor. The only other ignition point is the distributor cap. They occasionally develop cracks too small to be seen. Occasionally these cracks are temperature sensitive - cause no problem when cold but cause backfiring, etc when warm.
Carbs can cause problems as well if the needle and seat allow leakage. But I think backfiring suggests the dist cap.
