AC -6G Track loader
Nick T
02-02-2006 11:47:17
Hey guys,
I purchased this track loader w/serial # 6G75879. The tell me it doesnt match up when I call for parts. My problem is the left brake wont respond. Replaced brake drum and metal bands inside and put new pads on the brake shoes. No luck...I did notice that the pad tightener(bar that tightens brake pads) is all the way to the end while the right side has over inch left. Can anyone help? There is a 1/4 " of brake pad on the right side and 3/8" on the left. Am I steering this thing correctly when I drive it.
Hector gemme
02-02-2006 15:44:26
 Re: AC -6G Track loader in reply to Nick T, 02-02-2006 11:47:17
HI I check in my manual parts and the parts number for a kit lining is 076552 .HECTOR
Nick T
02-03-2006 06:00:29
 Re: AC -6G Track loader in reply to Hector gemme, 02-02-2006 15:44:26
Thanks Hector, do you know what yr. my track loader is? Do you think the brake lining needs to be replaced? I"m trying to get some response from the left brake. Do you have parts for that old tractor.
Hector gemme
02-03-2006 12:45:19
 Re: AC -6G Track loader in reply to Nick T, 02-03-2006 06:00:29
HI I think your hd 6 is 1960 and for the break lining I have 2 use set break band 2 1/2 inchs wide with new lining 1/4 and if yours are over size you will have probleme if the drum is standor and I have use parts for motor, cluch,transmission,stering cluch and final drive. HECTOR
Nick T
02-17-2006 16:32:18
 Re: AC -6G Track loader in reply to Hector gemme, 02-03-2006 12:45:19
Hector,
Do you have a manual I can purchase for this AC 6G. Also, how much for the brake bands and do you have a water pump for this track loader. We"re having problems with it over heating. Were gonna get the radiator looked at but we need to know location of water pump.
Hector gemme
02-17-2006 17:09:59
 Re: AC -6G Track loader in reply to Nick T, 02-17-2006 16:32:18
HI I just have one manual for me but you could check at your left on tractor manual.Y.T. and for the break band I want$150.00 with shipping and for the water pump she is on bottom the generator and she has one belt pully and I have some water pump but check the belt pully maybe loose. HECTOR
